Front Camera
  • Just completed install of Dasaita Vivid11 in 2019 Rogue. 360 camera works correctly when in reverse. Cannot view the front or rear camera individually. I assume the wiring is correct since 360 works.  Is there a setting or an app that's needed?
  • @Joe Shinault any resolution on this? I have the same issue.
  • @dasaita
  • @Dasaita Official@Chauncy Wilkins / @Joe Shinault
    Im experiencing the same issue where the front camera works in the around view mode but can't access independently (while in drive for example).
    Is there a solution for this issue?
  • Quick update, this issue is related to the factory settings.
    "Check the Can Bus settings (the following if for a J11 your J10 should be the same). Go to the PX5 factory setting, password is 126, go to : Canbus---Canbus: 10 NISSAN 2013 TEANA(Simple), Type: 1 Type Hi, Key Mode: AVM 5, press Apply then Exit, system will reboot"
