Android 10 Update
Vivid 10 Version: Make Sure your unit is PX6 Andorid 10
telenav_vivid_rk3399_10.0_ota(20230112)
https://www.dropbox.com/s/fopysof68tx9b1m/telenav_vivid_rk3399_10.0_ota%2820230112%29.zip?dl=0
System update tutorial(Please ignore the MCU upgrading instruction in the video as it's not essential now):
- Please download the document via your computer/laptop, then use the WinZip application to unzip the file.
- Please make sure to format the USB drive(FAT32 Format)/SD card before copying the update file to it.
- Please ONLY put Update.zip file in the root directory of the USB drive/SD card.
- Please note that all data on this unit needs to be wiped before updating the system, so back up important data if necessary.
- Finally click the Settings > System > System updates to start the update.
