Is there an update/upgrade available?
    I have een Qashqai J11 android unit with 360 camera system. I have lot of issues with WIFI, bluetooth, Camera's, steeringwheel keys and a few more issues. Is there an update or upgrade for my unit? see my current OS information:
  • @Ayhan Kirca Please let us know your OS(Max scout or Vivid) We will provide upgrade file accordingly.
  • @Support Dasaita it is a Max OS
  • @Ayhan Kirca
    Android 10 Update
    HA3_rk3399_10.0_ota(20230223)
    https://www.dropbox.com/s/8qfav7q3zzy0xv3/update.zip?dl=0
    System update tutorial(ignore the MCU upgrade in the video):
    Here are some tips to help you get the work done:
    1. Please download the document via your computer/laptop, then use the WinZip application to unzip the file.
    2. Please make sure to format the USB drive(FAT32 Format)/SD card before copying the update file to it.
    3. Please ONLY put Update.zip file in the root directory of the USB drive/SD card.
    4. Please note that all data on this unit needs to be wiped before updating the system, so back up important data if necessary.
    5. Finally click the Settings > System > System updates to start the update.
  • thank you
  • @Ayhan Kirca If the upgrade can solve your problem, would you mind sharing your shopping experience to other buyers which will be much helpful for us?
