Hi !
I have a little problem with the last update of the vivid 10 telenav_vivid_rk3399_10.0_ota(20230525)
I have installed waze application. When i launch it, the icon on the vivid launcher change to it (as old firmware). But, if i click on it, the google map application launch instead waze.
Do you have a tip for it ?
I have reinitialised the setting of vivid, reinstall the firmware with wipe, but still here.
Thank you in advance !
@Frank Blémont Would you please send us a video or photos to further demonstrate the situation that you mentioned? We will look into the issue and offer solution accordingly.
Of course !
There is the vidéo : https://photos.app.goo.gl/kiqQGsa6o2AkJEL77
Thank you!
@Frank Blémont Thank you for your remind and we have reflect the issue to our engineer for further improvement. You can just enter into the Waze app right through the icon on the home page. And once the upgrade version come out, we will inform you. Your understanding will be appreciated.
@Support Dasaita I have the same problem.... in the settings > navigation I have to set default app to Waze. I also have an issue / error with blutooth not working / App not repsondinf since the latest Vivid 10 upgeade. Previus Vivid 10 version was Ok...any ideas?
@Gary Fletcher-Moore We are wondering if you can shoot a video to show us a video so that we can better locate the issue. Meanwhile, please go to settings-about machine and show us your current built number and MCU and your order number if possible.
@Gary Fletcher-Moore the BT error has been fixed with the 20230801 build of the vivid rom
@Gary Fletcher-Moore Please upgrade your version to telenav_vivid_rk3399_10.0_ota(20230801).
https://www.dropbox.com/scl/fi/aaqv1utd0wx0t2rl4kyeq/update.zip?rlkey=ria0tfcoxbcioqh2pb9z38tzg&dl=0
i have same problem.
Waze icon start Google maps
@Edoardo Edo We would like to tell you that our engineer are still looking into the issue and will release firmware this month.
@Edoardo Edo @Frank Blémont We are wondering if you could update our latest firmware which has fixed the problem that you mentioned.
https://www.dasaita.com/community/forum/topic/36770/firmwares
Hi Support,
Please create an update fix for Android 9 PX6. This is a extremely annoying bug, but it wasn't bad enough for me to buy a new system.
Or could you suggest a way to upgrade the system to the latest version.
Thank you!!!
@Sophoam Caien We are sorry to tell you that the firmware on the forum of Android 9 is already the latest. Please kindly further demonstrate your issue, we will check and try our best to solve the problem for you.
Can fix this bug for android 9, i cannot start waze. Or could you suggest how I can upgrade to the latest OS.
@Jiohn asmithc Please send us your current Build Number and MCU version so that we could check if our firmware could fit your model.
