How to Set up CANBUS type
  • @Support Dasaita doesn't work. When I start the car the clock was correct and the 360 cam button working but just for 5/6 minutes. After these minutes the clock stay fixed and 360 cam button stop to work.
  • @ALESSIO FRATTARUOLO So everytime when you starting the car the 360 camera and the clock are work,but both of them only work  for 5/6 minutes,right?
  • There is no confirmation button
  • Hello customer,
    Thank you for your details.
    Could you provide your order ID so we could locate quickly to better help?
    Or please send the more details to this e-address :team@dasaita.com
    Kind regards,
    Dasaita
  • @Support Dasaita Order SP-DA4427, thank you very much
  • @Celestino Siddi
    @Celestino Siddi
    Thank you for shaing details.
    We found that your order came a cable CB004.
    Please go settings>car>factory settings>password:126>Canbus> Choose NO.8 .
  • @Support Dasaita Exactly. Just work a few minutes. After that the cunbus stops working. The time is blocked and the 360 camera button stops working too.
    Does the 360 button still appear on the page?
    In this issue,please try to find a pin to hold the RST for 15 seconds to enter factory restet
  • Which canbus do I select for a 2022 Toyota 4Runner? Thanks
  • Hi,
    I bought one year ago a android 12 for nissan quashqai 2015 - order N° SP-DA4654
    Everythings worked fine till suddenly I lost many functions, bluetooth, gps, rear cam ... I wrote about that and u sent me a link to make an upgrade, I did it, there was no changes about malfunctions.
    I have done a factory reset,( software & rst button), no changes !
    Actually canbus informations are
    Canbus : 10 NISSAN_2013TEANA(simple)
    left rudder, type: 1 typeHI, Key mode: AVM1
    Please would u tell me what is the right configuration to retrieve the original configuration ?
    best regards
