@David Warr Please send the video to our email support@dasaita.com
System updated now I don't have CarPlay it's telling me I need to reactivate and I need a code . Can I get the code pkease
@Joshua Hall I have a system for a 2019 tundra
@Joshua Hall Please go to Factory Settings > enter 126 > App and turn on the Zlink there. If no luck, show us the error you received so that we could better assist. Please kindly let us know your order number and shopping platform so that we could record and better follow the issue.
Note that your head unit should connect to Internet.
November 12, 2023 order date
order # 113-2522034-9156200
through Amazon
and non of that worked that you had suggested before hand
@Support Dasaita I added a photo and order info. This QR code is taking me to a phone number that doesn't dial out and cant download the app it mentions . Thanks for the help
@Joshua Hall We have forwarded the code the engineer and once it has been activated, we will let you know.
@Support Dasaita thank you
@Joshua Hall Our manufacturer said that the code had already activated, please kindly let us know if you have connected to the internet, if no, please have a try.
@Support Dasaita I posted this code again as it has not changed. I'm hooked up to the internet and still not working
If nothing else can I get the code so I can manually type it in? Thank you
@Joshua Hall Have you connected to the internet after we said that it had been activated? Send us a photo to show the wifi connection if possible.
@Support Dasaita is been stuck on android starting for two days now
@Support Dasaita and yes I connected to wifi picture above shows the wifi symbol I can't go to another screen. It just stuck in android starting.
@Joshua HallPlease find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, factory reset it. If you could enter the system, you could connect to another wifi or hotspot then reset the time zone to check if the zlink could be activated or not. Your cooperation will be appreciated.
