2016 4Runner Limited OEM reverse camera is not working it just shows triangle.
All of the cambus features seems to be working
Wiring seems to be correct.
Are there anything special that needs to be done?
I got the reverse camera working now and my newly installed front camera is working also!
@James Varney Glad to know that you have self resolved your problem.
@James Varney I am also having this same issue, how did you get it resolved?
@Michael Uribe We are wondering if you could go to Factory settings > enter 126 > Prohibit Reverse to check if it's set "Enable".
If the settings is OK, please kindly follow the post to check the wire.
If no luck, please take photos of the wiring so that we could further diagnose your problem.
Thank you for the assistance. I was able to get it working by changing the camera wire and also enabling the Prohibit Reverse.
Can you tell me why back up camera is not working? the canbus setting are correct. you see the wiring in the previous picture, is there another fix?
@Corbin Adams Could you please let us know your order number so that we could locate more order detail and give you instruction?
@Corbin Adams We are wondering if your issue has been resolved or not, your prompt reply will be appreciated.
