We've received feedback from some customers who are experiencing an issue with the rearview not displaying when reversing, but display rearview on the F-cam App.
If you're using the CB047, it's possible that you forgot to connect the reverse trigger wires C with C1 or C2. Please check the backside of your unit to ensure the correct wire connections.
If you need further assistance, please don't hesitate to contact us.
hello I have a 2013 non jbl 4Runner and just installed the G13. Everything is working except for the backup camera. The unit does not redo fixed when I am in reverse. The screen does not change when in reverse. How do I fix this? I have enabled backup detection. Do I need another additional harness than what was in the box? I am using the CB005-1+DYX004.
@Mark Mark
Thanks for your message.
Please confirm the setting firstly:
Settings > Car > factory setting (password :126) > Other > Reverse Detection > Enable.
Settings > Car > Factory settings (password :126) > Other > Front Camera > Off.
3..
Settings > Car > Factory settings (password :126) > Other > Switch to front camera after reverse > Disable.
Finally, tap "Apply" > "Exit "> "OK", then Reboot.
The front&back side clear photo of OEM radio.
