Feature Request: Allow to disable Audio Sink
  • Hi,
    Have been using the ZLink since 1 year with my after marker headunit, however, the sound output as well as the input (mics) are not as good as the built in ones in the cars.
    AAWireless adapter has the option to disable Audio Sink and TTS and allows that to pass to the Car's Bluetooth after the connection.
    Is something similar to this possible for ZLink and was it ever discussed ?
    Tried it with the AAWireless adapter and ZLink, it seems to be working that way, but would be great not have another adapter in between.
    AAWireless Adapter is connected to my Headunit which launcher Zlink Android Auto, and I connect to the AAWireless Adapter wireless.
    Thanks!
    Serhat
  • @Serhat G Sorry that our head unit could not retain the OEM mic, if your car has the OEM amplifier output, our headunit could normally supports. Please kindly further demonstrate your issue and we will try out best to solve the problem for you. It will be helpful if you could provide the order number so that we could locate your order detail.
