Will this procedure help to connect the OBDLink MX+ adapter to my G13? The Bluetooth module FSC-BW124 is installed. The device sees it but cannot connect. The HA5225 CB008 device for Nissan qashqai.
@Ronny K_Vcore
For your information, G13 doesn't support OBD Link MX+ adapter.
If needed, we suggest that you can connect this OBD:
https://www.dasaita.com/products/dasaita-obd2-car-automotive-diagnostic-scanner-save-share-reports-torque-app-plug-into-car-directly-car-diagnostic-scanner-tool?_pos=1&_sid=b6e3d4d0c&_ss=r
Thanks for the offer, but in this case I decided to use USB ELM327, it connected perfectly and works faster than Bluetooth OBDLink MX+. Advice to those who decided to connect the same way - in the adapter, the USB-UART converter should be on ft232, the drivers for it are in the system.
@Ronny K_Vcore
You are welcome :)
We appreciate for your advice as well.
