I've updated firmware, MCU, Bluetooth driver and Torque app to the appropriate levels as per Support articles.
Firmware: QCM6125 20240322
MCU: MTCH_HA4Z_V4.11_1
Bluetooth: BT1031p
Torque: 1.12.101.b112010
When I lookin the head unit Bluetooth devices, it only shows my connected mobile phone (Samsung S22).
When I look in Torque and check the OBD11 settings it only shows my phone.
Is there some setting needed to make the OBD11 device appear?
You have to go to Settings, Bluetooth and link the OBD once linked go to Torque and connect it.
@Iain Sherrit Please update the BT module to v5.0.9. (Go to Factory Settings > enter "hctbtup")
https://www.dropbox.com/scl/fi/um3zmkvtx81wejfkwulm2/bt1031p_update.bin?rlkey=16771kbsih5btwe0ts3a6qdsb&dl=0
You could connect your phone and then dial ****** to check the BT version.
@Support Dasaita HI, I have already applied the BT update.@Juan Perez
@Juan Perez Hi, the problem seems to be that the OBD11 device doesnt show up in Settings, Bluetooth hence cant be seen in Torque. I can only see the Bluetooth connection to my mobile phone.
Yes, of course, if the OBD does not appear in Bluetooth settings, logically you will not be able to connect it.
@Iain Sherrit Have you refreshed the device in the bluetooth connection page? You could reboot the head unit and then try to connect again, we have tested in a few car and there is no problem.
