Hi guys
Got a little issue with my unit
Got no dedicated AMP wire in my CB008 harness to command my subwoofer. The RCA sub1 and 2 are here for the music signal but no power command. Only 2 free wires called KEY1 and KEY2...
The blue amp wire is connected to a white connector linked to my 2018 Nissan Qashqai genuine harness.
Can I cut this wire and make a link to my sub? Don't understand why on Francesco Francy channel, there's a specific AMP wire on his cb008 harness and not on mine...
Thanks for helping me
@Nicolas ANTOINE Hi, we have connected the AMP wire on the CB008 by default as most of the this car model has OEM amplifier. If you want to connnect after market subwoofer, could you find that green subwoofer plug on the audio cable?
Yes I have the green RCA plug on the audio cable, but it's only the music signal and I'm looking how pilot the amplificator (shut it down with the unit).
@Nicolas ANTOINE We assume that you could refer to the following pinout.
Do I have to make a double connector? Does the unit needs this wire or can I disconnect it from the pin to manage the amplificator?
@Nicolas ANTOINE You may have to slice a piece out to connect your after market amplifier. We recommend you could contact with the customer service of your amplifier of how to install. Or you could find technician to help you.
Hello everyone. I finally cut the blue/white wire "amp" and connected it to the command line of my amplificator. I haven't any issue with OEM amplificator of the unit, and everything is running well. Just has to connect the RCA connectors to front R and L for the signal because no signal from the "SUB" line (?). Anyway my music found another dimension! Thanks for helping me
