SIM card for Dasaita G12 not working
  • I got SIM card installed on Dasaita g12 in the external module that comes with it.
    However, the module is not recognizing the SIM card is even installed.
    Any ideas how can I get the SIM card on it to work? I would like to have its own internet and not necessarily use in conjunction with the phone.
  • @Saad Zaman We are wondering if you insert the card in the right way. Here is an instruction.
  • There's only one way to insert the SIM card into the module  and that is as you have suggested it.
    I did that already.
    I think the issue is if I need to go somewhere into setting for the SIM card to be detected. Unless my module is not working ( even though I only purchased my unit a few months ago so it should be brand new)
  • Hello @Support Dasaita
    any ideas/updates ON this? It would very helpful to me if the SIM moduleis working
  • @Saad Zaman
    1、
    In order to avoid burning out, please make sure to shut down the car firstly,
    and then insert the SIM card.
    The SIM card should be fully inserted and heard "click".
    2、
    Please confirm:
    Settings > Car > factory setting(password :126) > other > SIM card voice call > YES > Apply > Exit > Reboot.
    3、
    Please tell us about the carrier of your 4G SIM card.
    At present, it mainly supports below US carrier:
    Verizon
    Bluewire
    Alaskacomm
    Sprint
    mobilenation
    Mohave
    Peopleswire
    Revol
    Commnet
    Distribution
    Union Wireless Data
    T-Mobile
    Truphone
    AT&T
    Inland
    Elementmobile
    If possible, please try to use other SIM cards to test how it goes.
    4、
    In order to learn your present version information,
    please go Settings > About Machine,
    then provide the following clear photo: Model; Android Version; Build Number; MCU version.
    Thanks in advance.
  • @Support Dasaita I have a verizon SIM and its not connecting me to the internet. It shows that my head unit is reading it but cannot connect. I have a g12 qcm6125
  • @Rudy Fierro
    Thanks for you message.
    For further confirmation, please tell us if you can make phone calls via SIM card.
    If possible, please use other SIM cards(T-Mobile/AT&T) to test how it goes.
    Picture: Settings > About Machine > Model; Android Version; Build Number; MCU version.
  • Order # 112-6176378-1637806
    purchased 12/29/2023
  • Cannot make phone calls.
  • T-Mobile sim card works fine, however I switched over to Verizon.
  • Go into your SIM settings and change it to LTE only, not whatever it is defaulted to (LTE + CDMA +GSM + etc.)
  • @Rudy Fierro
    To confirm further, please tell us if your Verizon SIM card can work normally in your phone.
    Based on your pictures, we notice that your current firmware&MCU are not the latest one.
    Please check the tutorial below and try to do the update firstly.
    System Firmware -G12-20241009:
    https://www.dropbox.com/scl/fi/a032ab14d1x48bmq8nf76/update.zip?rlkey=0mbc72a9ie2fgacpvr2ebliym&dl=0
    MCU-4.12b:
  • @Michael Uribe   Once you update to the lte settings only, does it work for you?  Also any specific carriers with whom it did not work?
    I have tried both AT&T and Verizon and it did not work.
    @Support Dasaita do you have any ideas other than updating the firmware from a FAT32 usb drive.
  • @Saad Zaman
    For your information, it currently supports to update via FAT32 USB drive only.
  • Ok I'm updating now.
  • The signal has an ! And still can’t connect to the internet
  • Also when I did the update it wiped out all my settings, apps installed, etc.... very annoying having to reinstall everything again..
  • 1 / 2
  • 2
