How to Install a Subwoofer to Your Car Navigation System
  • How to Install a Subwoofer to Your Car Navigation System
    We've had some inquiries about how to add a subwoofer to your car navigation system. Here's a step-by-step guide to help you through the process:
    1.Audio Line Connection:
    1)For connecting the audio lines of your subwoofer, you only need to use two out of the following: RR (Rear Right), RL (Rear Left), FR (Front Right), and FL (Front Left).
    2)Do not connect the subwoofer line directly.
    2.AMP Line Connection:
    1)Locate the amp line and carefully strip a small section of the insulation.
    2)Connect this stripped portion to the command line of your amplifier to ensure proper signal transmission.
    By following these steps, you should be able to integrate your subwoofer seamlessly with your car navigation system. If you have any further questions or run into any issues, feel free to reach out for more assistance.
    Happy driving and enjoy the enhanced sound experience!
    *****Please note that different types of subwoofers may have different wiring methods. You can consult the seller to confirm how to connect the wires properly
