Hello I really need help with my g13. I got my head unit and I installed it on my 2017 camry. It runs good few things here and they are not fixable but my main issue is the microphone. Whenever I'm on the phone the other side always says they either can't hear me or usually they hear themselves or that I sound like I'm in a tunnel. I did a test where I called another family member and I tapped on both internal and external microphones and for some reason they both are taking in audio. I tried buying a different external one but the same problem still remained. There is no option to select only external or whatever. I tried taking apart my entire stereo and disconnecting the external to only use the internal but the same problem still persisted. I checked all over the internet and no one has a fix. If I can't resolve this I'm probably going to return my head unit but does anyone have a fix?? The only time I "sound good" is when I'm parked and not driving. I emailed the company but they're not responding
@Moaz Albezreh
Thanks for your message.
Don't worry, we will try our best to help you.
For further confirmation, please provide the following information:
@Support Dasaita my order number is 112-0244062-9848266
My purchase date is October 28
@Moaz Albezreh
We have arranged the personnel to follow up on your order.
Please pay attention to your message box and discuss the details further with our personnel.
I discussed the details with your personnel and it ended up nowhere still the same issue after taking my stereo apart 4 times.
@Moaz Albezreh
Please be assured that we have reflected your issue to our technician.
Any updates, we will let you know.
Thanks for your patience in advance.
Have they got back to you, I am having the same issue
@Michael Pulver
Picture: Settings > About Machine >Build Number; MCU version.
@Michael Pulver yes they have. They sent me an update and it didn't do anything. I returned it and got another unit and it has the same issue. It's a simple option to add to only use the external microphone but for some reason they can't do that idk y. I was told to wait for an update or something
@Moaz Albezreh
Please be assured that now our technician is working hard to optimize the software.
Any updates, we will tell you further.
Testuj mikrofony aplikacją do nagrywania dziwięku. W moim starym radiu tego producenta problemem był wtyk mikrofonu który nie zwierał odpowiednich pinów w gnieździe mikrofonu i nie przełączał mikrofonu wewnętrznego na zewnętrzny. Trzeba zrobić zworę na płycie radia lub kupić wtyk z najdłuższym polem masy.
@Marcin Skwara
Translated...
Test microphones with a sound recording app. In my old radio from this manufacturer,
the problem was the microphone plug which did not connect the appropriate pins in the microphone
socket and did not switch the internal to external microphone. You need to make a jumper on the
radio board or buy a plug with the longest ground field.
I have the same issue, but not sure how the solution from Marcin applies? Not too comfortable making a jumper on the radio board.
I guess I'll wait patiently for the Dasaita support team to "optimize" the software like they promised.
@Tom Pierce
Hi Tom,
@Support Dasaita Hello, I got some instructions on updating my version and MCU from Support via email. Also, some tests to try. I will work on those and update you with the results. Thank you for the quick reply to my email!
@Tom Pierce
You are welcome, dear Tom.
If you need further help, please feel free to contact us.
@Marcin Skwara Niestety moja rada pasuje do starszych jednostek dasaita z miktofonem ze złączem typu jack.
I have the same problem with the G13. My interlocutor hears his voice coming back. It definitely takes the sound from the external microphone and the internal microphone. I saw that in the G12 there is the possibility to deactivate the internal microphone from the menu, which in the G13 this function does not exist. It is a big problem not to have good telephone conversations.
@Emiliano Di Nella
May we know the issue happen in using external microphone or internal microphone?
For your information, the setting is not working for the G13 unit. So we delete this settings.
