Microphone issues!! Plz help
  • @Support Dasaita il problema c'è sia con microfono esterno collegato e sia con microfono esterno scollegato.
    Io credo che entrambi i microfoni lavorano insieme. Sono entrambi attivi
  • @Emiliano Di Nella
    Ciao, abbiamo inviato il messaggio alla tua email, controlla e vai avanti.
    Con l'avvicinarsi del capodanno cinese, contatta la nostra email " team@dasaita.com " ufficiale per ulteriore assistenza.
    Grazie
  • Hello, I had to remove the 13.3 screen to make some connections behind the double din.  After putting things back together the screen does not respond touch.  I pressed the reset but still no response.  Any idea what I need to do? My unit is the vivid 10 universal 13.3PX6 4g+64g
    Also, are there updates for this unit?  I purchased in in 2022.
  • @Fred Traylor Please kindly try to use a mouse to calibrate the touch screen under the video instruction below.
    https://youtu.be/yaRKoQb1jlc
  • @Support Dasaita Yes, thank you!  The mouse worked but I had to do a factory hard reset.  All is well now!  Are there any updates for this unit?  I've had it nearly 3 years, I haven't done any updates at all.
  • I've also been having this issue for a few months now, the only fix I've seen anyone report is to take apart the unit and desolder the internal mic, which seems crazy.
  • @Ben Bowcott
  • @Fred Traylor
  • @Support Dasaita  On my G13 the call quality is poor and after a few tests I've noticed that the microphone used is the internal one, even though I have the external one connected. Some videos on YouTube show the option to choose which microphone to use in the settings, but I can't find that option on mine. I don't know if this is the solution to the poor call quality, but it should be an improvement.
    Order SP-DA6575 and purchase date January 10, 2025.
  • @Milton Nascimento Hi,
    Please make sure the mic is connected to the correct position.
    zst27_sc138_13_(20250226)
    4.15a MCU
    2.Format the USB drive(FAT32 Format)before copying the Update.zip hmcu.img file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
  • @Milton Nascimento i video che avrai visto saranno antecedenti agli ultimi aggiornamenti. Proprio dopo gli ultimi due nemmeno sul mio g12 non è più possibile trovare la voce per attivare o disattivare il MIC esterno dato che vorrei fare delle prove perché in chiamata l'interlocutore non sente bene la mia voce
  • OK, I've been trying different things and still having poor microphone quality on phone calls.  I replaced the microphone itself and located it close to the original microphone location.  Still poor quality.  I tested it both through carplay and through the Head unit software.  Same issues.
    Can you confirm that I have the latest software versions?
  • @Support Dasaita be careful with that MCU update (4.15a). I have just tried it and I got no sound on my Headunit (G12). I had to go back to 4.13 (the one i had previously) to get back the sound. Apparently the MCU governed settings (factory settings) were intact when the update, but no sound. Did you try that MCU upgrade before posting?
  • @Support Dasaita Hi. Today I had time and was able to confirm the installation and do the updates, but there were no changes. It's still only using the internal microphone.
    While I had the radio detached, I tried attaching and detaching the external microphone to see if there was any change, but it's as if I wasn't even connecting anything.
    As there is no longer an option to choose which microphone to use in the settings, I can see one of three possibilities:
    1. external microphone received faulty
    2. the 3.5mm adapter that connects to the radio faulty
    3. radio with faulty internal board
    The radio in the position where you connect the adapter has six pins and the microphone connects to the middle ones. Is this correct or could it be connecting to the wrong pins?
  • @Iker Gomez The update shared above in reply to my post is only for G13.
  • @Gerardo Pellegrini Maybe our problem is the same.
  • @Milton Nascimento Hi Milton,
    Could you please go Settings>About machine and provide the following version information so that we could better confirm.
    1.A clear photo of the stereo's Build Number.
  • @Milton Nascimento G12 and G13 relies on the same MCU (same SC138 platform) and MCU updates are compatible (unless Dasaita said the opposite with this particular update). MCU updates are completely independent for any particular Android Version (except for the fact that some old devices could be not supported due to the lack of specific drivers for specific bt/Wifi hardware) and the hardware support is removed from the Hardware list on the Factory Settings Menu
    But, as I said, the MCU update here presented resulted in NO AUDIO on my G12. I think @Support Dasaita should investigate this if there is a bug of this MCU update for the specific G12 units or is a particular case for my unit.
  • @Support Dasaita Hi, here you have the information you requested.
  • 1
  • 2 / 3
  • 3
