A few things that would make these devices shine
  • 1. More control over the screen brightness. It's too bright at night.
    2. Don't turn the screen on if it's off, when adjusting volume or seeking forward/backward, etc. Basically if the screen is off, don't turn it on in response to steering wheel control button presses.
    3. Don't block steering wheel controls from working while the volume display is on the screen. I frequently will turn volume up or down, but then seek. The seek buttons will not work until the volume display fades away.
    4. Don't block steering wheel controls while in reverse. Volume works but seeking does not. Both should work.
    Thanks!
  • @John Robinson
    Hi John,
    To better follow the questions,please attached the order details to Dasaita Official Team E-address: team@dasaita.com
    Thank you fro your time and patience in this matter.
  • @John Robinson I have the same problem with the screen, it's much too bright at night, it's really blinding! I also have G13, I also contacted them and sent all the data from the radio, Dasaita's recommendations didn't solve the problem, so I was forced to install the Night Screen app and it works really well, the only disadvantage is I always have to activate the app when driving at night.
  • @AO1967 Hi there,
    In order to better improve the user experience, we will optimize the user experience through statistical analysis.Actually,we have reflected those feedback to out department,your suggestion has been take into acocunt,thank you for your time and patience in this matter!
  • For screen brightness just activate Google assistant and say open accessibility settings there is a dim setting which you can set the brightness to what ever you desire and it adds a quick setting in your notification screen
  • Now a lock screen for when your car is at the mecanic so they cant play around with it would be good
