As stated above. No sound at door speakers.
was working, let it sit for a couple hours, started truck up and no sound.
I've reset the radio already, I've factory reset as well.
databus is set to option 8,
Pic is mcu and build number
I've tested for power at the speaker and there is no power at the speaker. If i disconnect and reconnect the amp connector for the speakers, i can hear an audible thump.
@Alexandre Silva
Hi Alexandre,
zst27_sc138_13_(20241121)
②4.15a MCU:https://www.dropbox.com/scl/fi/lup0rygoff52bfyy4u4vo/hmcu.img?rlkey=ljxdd49so7dr37qedomg3zdr9&dl=0
2.Format the USB drive before copying the Update.zip & hmcu.img file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
MCU updated:Settings>System>MCU updates.
