Option to change backup camera aspect ratio
  • I recently just installed the G13 on my 2020 Toyota Corolla XSE. One thing I want to see is the option to change the aspect ratio of the back up camera to stock, instead of being stretched out by the whole screen.
    Please let me know what you think,
    Thanks.
  • @Karl Pineda Dear Karl,
    Could you please sharing a pic of showing that ?
  • @Karl Pineda
    Hi Karl,
    Since your original radio acreen size is different to our radio.it's 12.3 screen,the image will a little bit stretched.There is no setting to change it.
  • @Support Dasaita yes exactly. Is there a possibility of flashing a custom firmware or something for it? I assume it's easy to change the aspect ratio in the code somewhere to make it fit, even a 1:1 aspect will suffice
  • @Karl Pineda
    Hi Karl,
    Thank you for your suggestion,we have reflected to the engineer. Actually the image it looks normal, maybe a little bit stretched.since it is the first time that we've met it this question,we will take into account.
    Thank you so much for your suggestion.We will inform you when we accomplish it.
