Can I change the default navigation app from google maps to another maps app that I install?
Basically, when I tap on the big navigation card app from main screen to be redirected to the new app that I install?
Thank you in advance
@Bogdan Andrei
If you're referring to change the default navigation on G13 unit, please try to go Settings>Car>Navigation>Navigation application options> Choose the another maps you install on unit.
I've a similar request. I already linked my navigation software SYGIC as standard navigation. However I failed to put it into the dashboard. By tapping on the navigation widget SYGIC opens as full screen. It would be great to see it in the widget. How can I handle this.
@Adolf Klenk
Please try to go Settings>Car>Navigation>Navigation application options> Choose the another maps you install on unit.
If not luck, you could customize the navigation on the left widget ,see this video for reference:
https://youtu.be/70A4WPuWEWY?si=_92JGWneZIqnL41j
