Hi, I recently installed a new radio (Dasaita G13), and while everything seems to be functioning properly, I'm having trouble with the radio stations. They're not picking up any signal, and all I get is white noise (OEM radio image attached).
Has anyone experienced this issue before or have suggestions on how to fix it?
I'm having the same problem
@Jonathan Marino
About the radio issue, here are some trouble-shootings for you:
1).
Please confirm that you have plugged radio antenna properly the there is no loose situation.
2).
Please make sure that you have selected the correct region:
Settings > Car > Factory settings (password :126) > Radio > select your region.
3).
Please disable RDS function:
Settings > Car > Factory settings(password :126) > Other > Radio RDS > Off.
@Juan Guzman
1).
2).
3).
