I successfully installed my unit but I have some issues:
1) when using Zlink and Google Maps on Android Auto, the first words of every navigation instruction are cutoff. For example instead of "At the roundabout take the first exit" it plays only "-bout take the first exit". Can it be fixed? It's pretty annoying.
2) there's a gap on the right side of the screen, see the image. do you have any tips or is it normal?
3) is there a way to show RDS other info (for example: artists and song playing)? with OEM radio I was able to read them
4) is it possible to customize left panel button? I'd like to associate navigation button with Android Auto, so I could switch from radio (music icon) to Android Auto (navigation button) with just a click
Omar
@O F
Thanks for your message.
1)
Please check the update tutorial below and give it a shot.
System Firmware-G13-20241223:
https://www.dropbox.com/scl/fi/reyor35eptoeqwps98zn4/update.zip?rlkey=2pwefyw8tufqo0un3kpkqxy1q&dl=0
MCU-4.15a:
2)
Could you please record a clear video to show a gap then send it to us?
Based on your photo, we cannot learn the gap situation clearly.
If it is the small gap, then it is the normal situation.
3)
For your information, it doesn't support to display the related info.
4)
Please try to do as follows:
Settings > Car > Factory settings (password :126) > Key Study > Touch Key Study.
Here enclosed the video for your reference:
https://www.youtube.com/watch?v=Is1yyN3BegI
2) https://photos.app.goo.gl/dSAiwrANbsanxDjt5
As you can see left side is perfect, right side isn't, there's a visible gap. Do you have some mount advice or I have no chance to fix it?
4) I restudied the touch keys but I'm unable to find Zlink shortcut to associate it to navigation physical button, am I missing it?
Thanks in advance
@O F
1、
Please try to reassembly unit, make sure to be centered and installed properly.
2、
Upon checking, regret to tell you about it doesn't support to customize left panel button to Android Auto App.
In this case, we suggest that you can set up the left menu on the home page.
So that you can tap to open Android Auto App.
