After upgrade bluetooth doesn't work anymore
  • Hi everyone!
    I own a PX6 (1280x720) running Android 10. The other day, I decided to update the system after discovering several available firmware versions.
    After updating to Vivid 10 Version: telenav_vivid_rk3399_10.0_ota (20240126), performing a wipe data and formatting the flash, I noticed that when connecting my phone to use Android Auto, there is no connection between them, although the initial pairing is successful.
    I also tried another version, MAX10 Version: HA3_rk3399_10.0_ota (20230803), but the issue remains the same. Additionally, I have attempted the option reset bluetooth devices, but the connection issue persists.
    Any ideas why this is happening? Possible solution?
    Thanks in advance!
  • Hi Enric
    Please try to fatory reset the unit to see how it work?
    If you try but no luck please kindly get back to us.
  • Hello thanks for your reply,
    I did but unfortunately with the same result...
    factory reset
    The pairing its successful but still no conection between, before the update I was using zlink3, I don't know if this can be related to the problem? it's weird, next step what can I try now?
  • @Enric Subirana
    Hi Enric,
    https://www.dropbox.com/scl/fi/05xsn33yaco1qzc8fmn2v/update.zip?rlkey=7lj4j3l1unpb7mured9svoc2g&dl=0
    1.Download the documents through the link on your computer/laptop.
    2.Format the USB drive before copying the Update.zip file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
  • Thanks for your help! Please, can I have the last version (doesn't matter if its MAX, VIVID, HCT...) that is using Zlink3??? How I regret to update the system
