No Max A/C air conditioner after installation
  • I just finished Dasaita Android 13 head unit to my Toyota Camry 2012. However, when I turn on the AC to Max A/C, it is not working. For Toyota Camry 2012, in order to have the AC running cold, it has to be on Max A/C.
    From picture 1, you can see that the knob turns to Max A/C
    When I turn on the AC, the Max A/C is not highlighted as picture # 2 below where I circled in red
    and the rest of the pictures below are my head unit specs.
    Could someone please show me how to fix this issue?
  • @Ta Ody
    Thank you for your contact.
    The unit doesn't support the Manual Air Conditioning, so Max A/C air conditioner is not showing on the Dasaita unit.
    Just would like to confirm can the Max A/C air conditioner work porperly ? Or is only not showing on Dasaita unit?
    We thank you and look forward to your reply.
  • Turned out it was my car A/C leaked Freon gas. So I took it to body shop and they pump freon gas in, everythign is working now.
  • @Ta Ody
    Thank you for your update.
    For any other helps,please get in touch.
    Kind regards,
    Dasaita
