Slight popping from speakers and low volume
  • 2017 sierra with bose. Recently installed a g13 unit. The volume is lower than the factory unit and i have a slight popping or crackling from speakers at higher volume. Im guessing it may have to do with the bose amp that is factory in my truck. Any help is appreciated.
  • @asher condon
    Since the BOSE AMP is high output ,how about we send you a audio output to have a try ?
  • that will work for me.
  • @Support Dasaita what info do you need from me to send?
  • @asher condon
    Just would like to confrim the pop sound only happen on higher volume? How is it going when the unit is on lower volume?
    We appreciate it if you could send a video of showing the sound issue to better confrim.
  • @asher condon
    If possible, could you disconnect the red and white RCA cable to check how is the poping sound going ?
  • @Support Dasaita  Popping is more noticable at higher volume but still that at lower volume, i did disconnect the red and white onstar rca's and it did not change anything. I will attempt to get a video or audio clip but it is difficult to hear through a recording.
  • @asher condon
    Thank you for your reply.
    May we also know how is the F°  working?
    Looking forward to your reply.
