@yuanrapido hola buenas, tengo una dasaita PX5 con android 9 en mi nissan qashqai y nunca se me actualizó, queria saber cual es la ultima actualización para mi radio para poderla actualizar. se podria actualizar a android 10 o vivid?
muchas gracias.
@Quick Yuan La actualización (telenav_vivid_rk3399_10.0_ota (20211203) si funciona para dasaita vivid (modelo HA5225-Vivid10-CP-HD) si alguien va a hacerla asegurarse de que no tiene dos usb conectados a la unidad sino no actualizara, por si a alguien le sirve de ayuda.
Any solution to put an Android 10 on px5? Im on Android 9 actually.
@Quick Yuan Why is there no extensive equalizer in the latest VIVID update, and already in the newer MAX 10 update there is?
Hi, ive got my new Dasaita 9" 1 Din Auto Radio für Honda Civic Hatchback 2012 2013 2014 2015 Multimedia Android 11 10 Carplay android Auto GPS DSP
The following works:
- iGo Navigation
- DAB+
- Radio
- Wifi
What does not work:
- ipod (Classic) 120GB
- bluetooth
The iphone XR is not found. What am I doing wrong or do I need to set up so that my iphone XR connects with bluetooth and also my iPod works.
I have now done a factory reset once and now have one more ICON on the unit: - USB/iPod, when I connect the iPod (to both black and also gray USB port) nothing happens.
Do I have an old android software on the unit?
If imoprtant, is live in germany.
Hope you can help me and fix my two problems.
greetings Marco
I have been able to solve the problem. To connect the iphone with the android unit via bluetooth the following must be set in the car settings:
BT: FSC-BW124
Maybe only in germany and for an Civiv Type R - 2015
cheers
@Quick Yuan Can the firmware W11 Version HA3_rk3566_11.0_ota(20211115) be installed on a PX6 MAX10 version?
Is this version Android 11 and does it contain the same apps as the Android 10 version?
Hello, I have installed in my Civic 2017, the firmware MAX10 Version : HA3_rk3399_10.0_ota (20210811) and MCU 3.78.
Now the wireless Android Auto works for me and I'm happy.
But after installing it, the Lane Watch stopped working only shows a yellow triangle
The configuración is Rigth View Normal.
How do I install maps in scout
Hola, tras la actualización de mi dasaita px 6 max 10-cp-hd a la version Versión MAX10 : HA3_rk3399_10.0_ota(20220120) ha dejado de funcionar el bluetooth. No se detecta con ningun teléfono
@gorka ebben
PArece que hay un bug en el software. prueba lo siguiente
Ve, en tu pantalla dasaita, a Settings> connected devices > Bluetooth (es deicr a la configuracion de bluetooth de android, no de vivid, ni de dasaita) y alli ejecuta tu busqueda de dispositivos....aparecera el tuyo y empareja tu movil desde ahi., en esa misma pantalla veras que esta el codigo d emparejamiento... Luego, una vez emparejado, ya lo veras activo en la configuracion de bluetooth de la ROM Vivid o la Rom Dasaita de forma normal...
Pruebalo y dime si te funciono, pues creo que mucha gente tiene ese problema (a mi me paso anteayer) para hacer un video y subirlo
@Diego Etchecoin do you have a "car information" app available? in some vehicles (mazda, toyota) apart from the factory settings canbus tab, this app allows to configure some car specific options. Check if there is the app and if there is an specific option for the feature you are looking for
@Iker Gomez Hola, he probado de instalalar una version antigua(PX6 android 10) HCT7_rk3399_10.0_ota(20211109) y con esta si me encuetra el bluetooth de nuevo pero al volver a poner la nueva no lo encuentra. como se accede a los ajustes de android y no de dasaita ?? Muchas gracias
@Iker Gomez el problema es que no me encuetra ningun dispositivo y si miro en permisos el bluetooth se ha quedado sin permisos y no me deja la opcion de dar permisos. Se ve pero no me deja clicarla.
Hello. I have a PX5 rk3368 - 4GB ram, MTCE with Android 9. I flashed the latest MCU 3.78 from this thread but I am a little confused with the roms. Which rom is the latest and suitable for my unit? Thank you!
@gorka ebben
Settings > Connected devices > Bluetooth
@gorka ebben ese parece ser el problema base, que los permisos de acceso al blueooth estan deshabilitados
I visit this page daily and noticed the new MTCH 3.80 software update.
I currently have a Dasaita Max 10 with MTCE 3.78.4. Am I safe to install MTCH 3.80 at all, or is 3.80 for a different hardware?
Tks :)
Firmware Updates - PROBLEM
I am trying to update the firmware of MAX10 Version: eng.htc.20211015.134821.
I am trying to install: HA3_rk3399_10.0_ota(20220120)
but each time I am getting an error message:
E: Signature verification failed
E: Footer is wrong
E: error : 21
I have also tried other firmware, unfortunately with the same effect - ERROR
telenav_vivid_rk3399_10.0_ota(20220215)
So I tried with 3 separete firmware and I got error message each time.
am I doing something wrong ?, can you please advice.
the new ... MTCH 3.80 : https://www.dropbox.com/s/4kl7j2gsgdjt527/MTCH_HA_V3.80.rar?dl=0
is compatible with MAX10 Version:HA3_rk3399_10.0 ???
