My iphone connects via zlink just fine wirelessly. If I plug it into the grey USB port, Does Zlink autmatically got to tethered mode? How is the Tethered hot spot switch enabled so it can be turned on?
Here is my use case:
The iphone knows its plugged into the USB(Grey). Could there be a bug in the tethered option on/off control? It seems if this switch would work and the head unity knows that I am tethered, I would not need to go thru this sequence to get Android apps internet connectivity.
Now Adroid apps will connect.
