If you set the Bluetooth pin number to e.g. 0000 and perform a reset by the reset hole. The pin number is changed to a random number different from 0000.
yes, the vivid design is ramdon password ; in case stranger can guess out the password and connect to the device
@Quick Yuan You call it a feature, I still call it a bug. If you set a random number once noone will be able to figure that one out under normal conditions.
@Tom Box thanks for feedback , we will consider update next version
