MAX10 upgrade to Vivid 10 or I can run the Vivid apk on top of Android 11?
  • Hello, I just received the MAX10 PX6 with Andoird 11. It came with the stock UI.
    I would like to run Vivid.
    Can I just install the Vivid APK or do I need to flash the latest Vivid 10 (telenav_vivid_rk3399_10.0...) ?
    Please let me know.
    Thank you,
    Zeek
  • @Zeek World You can simply install the VIVID apk. It works the same.
  • But there it has to be a difference between a vivid 80mb apk and a vivid 1.3gb image.
    Otherwise I don't see the point of installing the large image at all.
  • @Zeek World The 1.3gb image has the OS in it. The APK is just the software running on the OS.
  • Hi, Zeek World,
    Pls reply us ASAP, thanks.
