Bluetooth, wifi and clock problems
  • Hi, just bought for the first time a screen for my Nissan running Android 11. After setting it all up, I came across some problems with it. Bluetooth only connects 1 out of 10 times, unable to launch the research for any. wifi is the same deal. I also have trouble with the clock, unable to change for other timeline than China, and when putting it manually it always go back. Is it best to return the product or will we have an update fixing those issues? Can I downgrade the android 11 to 10 by download?
    thanks in advance!
  • Downgrade/upgrade android versions is not a direct procedure like upgrading via OTA to the same android version.
    The issue that you are describing has been addressed by the developers...and I think it is solved on the today's OTA release.
    Please enable.wipe when system detected the update into your USB drive:
    https://www.dropbox.com/s/xoy332fcx7t7bfn/telenav_vivid_rk3399_11.0_ota%2820220413%29.zip?dl=0
    I recommend you to uog
  • @Iker Gomez My version is RK3566, is it still the right update?
  • Hi Sylvain, in firmware download you find last version for your chip-set
    W11 Version
    HA3_rk3566_11.0_ota(20220214)
    https://www.dropbox.com/s/om4kil7nt1lvx6u/HA3_rk3566_11.0_20220214_ota.rar?dl=0
  • @Sylvain Grenier sorry no...go to the corresponding latest version for your chipset.,.as pointed by Pasquale
  • Hi, Iker Gomez,
    Pls reply us ASAP, thanks.
  • Hi, Sylvain Grenier,
