Just like the title says. I can see the device but it won't connect no matter which method I use. (Bluetooth app or Settings>Bluetooth)
How can I get this to connect?
I figured it out. You have to set the head unit's Bluetooth configuration to 0000 in order to connect to OBDLink devices.
I also use OBDLink MX+, it was quite a process to connect it for the first time, after that everything goes very well. OBDLINK support didn't help much.
@José Guillermo Huertas Lancheros
How did you manage to do that? I also have MX+. G13 also only sees it and does not connect ((((((
0000 not help...
@Ronny K_Vcore
For your information, G13 doesn't support OBD Link MX+ adapter currently.
If needed, we suggest that you can connect this OBD:
https://www.dasaita.com/products/dasaita-obd2-car-automotive-diagnostic-scanner-save-share-reports-torque-app-plug-into-car-directly-car-diagnostic-scanner-tool?_pos=1&_sid=b6e3d4d0c&_ss=r
