Dasaita Vivid10 on 2014 Toyota RAV4 LE
  • I have installed Dasaita Vivid10 (SKU: HA5632-Vivid10-CP-HD) on 2014 Toyota RAV4 LE. Audio, GPS, navigation, Bluetooth, phone dialer, android auto seem to work OK so far. However, when I put car in reverse, the unit shows a black screen with an explanation point in a yellow triangle. This is a stock backup camera and it used to work with the OEM audio unit. Dasaita unit has CANBUS. Any ideas how to make stock backup camera to work would be greatly appreciated.
    Michael
  • @Michael Sahin Same thing happened for me when I installed the unit on my Camry. Please check the camera video cable label, you must forget to connect those two camera cable together.
  • Swap the two yellow camera connectors.
  • If everything is correctly installed then check an option onto the factory settings >others (password 126) to enable reverse camera
