Dasaita 9” Inch Car Stereo (this product: https://smile.amazon.com/dp/B08Q3HGG7N)
Installed per the included instructions and everything is working (wifi etc.) but I am not getting any audio from the unit at all. I assume this had to do with my Ex-T trim having an amp possibly? Any clue on how I'm supposed to modify the harness to account for this?
Thanks in advance!
@James Noles
1)If your unit has an integrated amplififer...you must check that you received a Canbus Box
2) Configure correctly the canbus on Factory Settings (password 126)
Hi. Just installed g12 in my 2018 ext. it has an amplifier. I am also not getting any sound. It came with the cambus and using 21. Do I need a different harness?
@James Noles did you ever find a solution?
