I recently installed PX6 Daisaita Scout 10 Head Unit on my 2016 Camry. I have also downloaded and copied the TelenavMapData folder to the unit flash folder for offline navigation.
Unfortunately, everytime I try to enter an address, nothing comes up. I have to connect to the internet to use the navigation. Can anybody help me on how I can use offline navigation even after I have downloaded and placed the maps to the flash folder.
Thanks So Much!!
Umair
Thanks for reaching out.
Please do make sure the map data is unzipped in your USB stick and then copy the unzipped folder to the root directory of internal storage.
The map folder in the root directory like the screenshot below.
I have done this. But I'm not able to use the map offline. When I connect the head unit to internet it works perfectly. But since we have the maps in the flash folder, I should be able to use offline navigation.
Can you share what you did if you get it to work I would like to have navigation while being offline, thank you
