I have no idea how to update or what firmware to update
  • Can someone guide me in the correct direction to updating my headunit?
  • Hi, this is the latest OTA update for your system: https://www.dropbox.com/s/h8zjji07bn8mopo/HA3_rk3399_9.0_ota%2820211023%29.7z?dl=0.
    Download the file from this link and once downloaded unzip it, a XXXXX.UPDATE file will appear, copy it to a clean FAT32 formatted USB memory. Once this is done, insert the USB into a USB port of your Dasaita unit, wait a few seconds and a dialog box will automatically appear informing you that there is an update available, click install, this process takes about five minutes.
    The other update is the MTCE whose current version is 3.78, the process is similar to the one described above, only that when you download the file, one appears with a dmcu.img extension and you just have to copy it to the USB.
    Once the USB is inserted into your Dasaita unit you can also go to settings/system/system update to run the installation.
  • https://www.dropbox.com/s/h8zjji07bn8mopo/HA3_rk3399_9.0_ota%2820211023%29.7z?dl=0
  • MTCE MCU
    3.78:https://www.dropbox.com/s/3hd3ci3rp07ddnt/dmcu.img?dl=0
