Need too long to find GPS signal
  • Hi all, for the last few weeks I've been having problems with the GPS, when I start the vehicle in the morning and drive to work it takes at least 5 minutes to figure out where I am, it doesn't lock onto any GPS signal until 5 minutes have elapsed. This is a problem because I've often already taken a route and can't change it, and it didn't do this before.
    When it locks onto the GPS signal it works fine but it takes a long time to lock onto it.
    What can I do?
    Thank you!
  • @Gioele Corsinovi what changed in that weeks?
    Dis you perform any upgrade?
  • Hi, no, nothing has changed I think. By the way, I also updated the firmware to version HA3_rk3399_10.0_ota(20220824) and I don't notice any changes. I only see that with Google Maps it locates me sooner, Waze takes longer....
  • The same thing happens with my PX6 android9, it takes about 5 minutes to catch a GPS signal. Once it receives a signal, it will continue to receive as long as the power is not turned off, but if I turn off the engine, it takes a while to receive again.
    I reset it and updated the firmware, but the situation has not changed. What could be the cause?
