I just updated to the latest Vivid 10 version
Vivid 10 Version: Make Sure your unit is PX6 Andorid 10(Combine scout and vivid)
and have two questions:
- How to you select which launcher is being used now that Scout and Vivid are combined in the update?
- I keep getting to a Scout setup screen where select the language, accept the TOS, and then get to a WiFi setup screen that just keeps showing a spining icon. Do I have to be near a WiFi access point to activate Scout? I turned on the hotspot on my phone but still nothing.
Thanks.
@Emmett Pate We would like to tell you that vivid and scout is from the same company. You could download the Scout map in the launcher and turn it into Scout. Please confirm if you have connected the wifi ant as it will require strong signal with wifi for the first connection.
Thanks. Yes, I finally got it activated by disabling bluetooth on the phone so that Zlink and Android Auto wouldn't auto-connect (which apparently turns off WiFi on the head unit).
Also like to add that the connection speed for wireless Anroid Auto is considerably faster (maybe 5-10 seconds at most). Not sure if was new firmware or the latest version of AA on the phone (10.7.634214), but it's a huge improvement.
Good afternoon, I just installed it on my dasaita and in the classic theme, I can't remove the clock and speedometer on the left and put the navigator map, can you tell me how to do it?
@Quique Escobar We would like to tell you that it's fixed widget, you could installed the Scout map and it will be replaced the speedometer on the left. Please let us know if you want, the APK will be sent to you once getting your reply.
Thank you very much for your quick response, I will be delighted if you send that apk and thus install the map on the left side, thank you very much in advance.
Thank you very much for the help and your quick response.😀
Hi Dasaita,
I would also like to have the Scout Maps on the left side of the dashboard. Can you send me the APK? Thanks
@Artur Monteiro Please update the firmware to the latest vivid11.
