Hello all,
What is the latest version of zlink and is it possible to update it?
Thank you.
Hello all,
Thank you.
From my understanding it can only be upgraded by updating your firmware/system software. It is not meant to be an app that end users can update.
I see, but do you know what is the latest version of zlink?
@H H We found your message in other post, we are wondering if you could factory reset the system first.
@Support Dasaita Hello, I have not since I am afraid I am not able to put back the correct settings.
Does reset make a different?
Thanks.
@H H Reset may delete some original settings. But it will not influence the usage of the head unit.
I have received an apk from someone and able to update from 5.4.20 to 5.4.27.
however, I am experiencing disconnect issue with 5.4.27, wondering if there is any newer update available.
thanks.
@H H was 5.4.20
