@Philip Figueroa My USB Key is a 2.0. Installation also performed using a new KEY 2.0 and the installation failed anyway. I think it is appropriate that firmware updates should also be distributed via OTA in order to eliminate similar problems to mine and other users. Thank you for the suggestion.
@Antonio Catalano
Usually we use the USB driver (FAT32 Format) to update the firmware.
Can your USB Key 2.0 be recognized the USB music on Dasaita unit?
If yes, please check if the firmware format is correct. The name of file is Update.zip
Please send a picture of your file details,thank you.
"Usually we use the USB driver (FAT32 Format) to update the firmware."
Formatted two USB KEY 2.0 in FAT32. One already used and one brand new.
"Can your USB Key 2.0 be recognized the USB music on Dasaita unit?"
Yes
"If yes, please check if the firmware format is correct. The name of file is Update.zip"
Procedure known and performed as indicated in other posts. Already done for other problems without any problem
"Please send a picture of your file details,thank you."
as soon as possible
