Radio tuner stop working
  • Good morning, suddenly the radio tuner connected to the car antenna stopped working.
    Installed on Nissan Qasqahi year 2010 -
    Even the Radio apps do not allow searching for FM/AM channels.
    The antenna cable is connected, I also tried to RESET the system.
    all other possibilities (streaming etc) for listening to music work
    any suggestions?
    I can go back to Vivid Android 10 because in the last automatic system update It switched to Scout?
    Can I possibly update the firmware and if so which one do you recommend?
  • @luca ricciarelli Please kindly update to the latest version.
    Vivid 10 VersionMake Sure your unit is PX6 Andorid 10(The left widget's map could be customized, suggest Google Map and Scout Map.)
    telenav_vivid_rk3399_10.0_ota(20240126)
    https://www.dropbox.com/scl/fi/9whz1p3ovge2ga2g75m8x/update.zip?rlkey=n9yitv3tnx3vzgaixesru94s8&dl=0
    If no luck, we are afraid that the cable is defective that you may need to change it. Besides, please send us your order number so that we could record.
    I did the update you recommended but it still remains Scout 7.3.28
    it also deleted all apps.
    is there another way to reinstall Vivid?
    Order nr SP-DA1734
  • Go to vivid settings, general screen on the right side, Exit and click Factory Reset.
    Just restart Vivid once you have configured it if the map does not appear on the Left side.
    Restart Dasaita and you will see that it appears.
    I hope this helps you.
  • @luca ricciarelli We are wondering if the radio could work after the update of the firmware, you could go to Settings > About Machine so that we could check if your update is successful or not.
    Unfortunately, despite the update, the radio tuner does not work
  • @luca ricciarelli Could you go to Factory Settings > enter 126 > Radio to check if the radio receive country is correct or not?
    Same problem for me. I am struggling with radio connection since the change from Dasaita to Scout. With the previous update of the firmware it worked without intreruption for 2 days, but my phone was not connecting anymore.
    I made the upgrade once again to Scout Model PX6; android version 10; software vesrion 7.6.4551 and now the radio it's not workink at all.
    I checked also factory settings and everything it's ok.
    Any advice?
  • @Razvan Ionut
    Order Number; Purchase Date.
    Regarding to your issue, please try to update the firmware.
    Vivid 10 Version Make Sure your unit is PX6 Andorid 10
    Step1.
    Step2.
    Step3.
    Step4.
    Step5.
  • Buongiorno , ritorno alla discussione dopo aver provato aggiornamenti vari per ritornare a Vivid ma rimane installato Scout.
    C'è una procedura manuale ? ho preso il prodotto con Vivid , si è aggiornato autonomamente a Scout , la radio non va più, tempi di accesso al gps lunghissimi.
  • Rivedendo il video durante la fase di aggiornamento  a me non succede questa fase
