I have a 2011 sr5 basic head unit and the large metal brackets and small plastic brackets that you transfer do not fit pre existing holes.
@Jason Hall Hi customer, we are wondering if you could let us know your order number so that we could record your case. According to your photo, it seems that your bracket is the same as the following one.
Order number 112-6022183-2485861
what is the fix with the small black plastic brackets that need to be transferred from the original radio the holes do not align with the new radio.
@Jason Hall We have sent you an email, could you please communicate with us there.
@Jason Hall I had the same issue - the bolt pattern is wrong.
I haven't gotten a reply from them, can you let me know how you fixed it? I just did the best I could and I'm hoping it holds up but it is wiggling a little bit.
Also were you able to get steering wheel controls to work, as well as the pre-amp ("party mode") switch?
I have the 2013 4runner and the G12 came with three wiring harnesses - the one for my OEM stereo (CD player) was the only one without a CANBUS breakout (reddish plastic box). The amp switch does not work, steering wheel controls do not work, and there's no car data (open doors, RPMs, MPG, etc). I'm hoping I did something wrong!
@matt f
If possible, could you please write a mail regarding to this issue and indicate your order number?
So that we can arrange the personnel to follow up on your case and offer the corresponding after-sales service better.
✉️Email: support@dasaita.com
