Scout update blocks Dasaita, how to solve it?
  • Greetings,
    my Dasaita Vivid 11 every time this update appears and I run it, it freezes at the home screen and I'm forced to restore it..
    The seller asked me to install the Telenav_vivid_rk3399_11.0_ota firmware
    is this correct?
    looking in the settings of my dasaita it seems that this update is already there...
    Can you tell me which is the correct update to launch?
    in attach the details of firmware on my dasaita PX6
  • Hi Ivan,
    Please update the firmware to the latest version via the link below,here are some tips to help you get the work done:
    telenav_vivid_rk3399_11.0_ota(20240604)
    https://www.dropbox.com/scl/fi/1clw6dqa9zmxfr717uuwh/update.zip?rlkey=ltfea919b8ytclpytaqfjlser&e=1&dl=0
    1.Download the document through the link via your computer/laptop.
    2.Format the USB drive before copying the Update.zip file to it, then insert the it to the USB cable,it will pop out the firemware updating tips.
    If any question with the updating,please feel free to contact us!
    Best Regards,
    Dasaita
  • Hi, in addition to performing this update, is it necessary to update the MCU version?
    Which filesystem should I format the USB drive with before copying the zipped update?
    To start the update on my tablet where should I click?
  • @Ivan Di Deco Hi lvan,
    Do not need to update the MCU version.
    Please make sure to format the USB drive(FAT32 Format)/SD card before copying the update file to it.
    When you insert the USB drive which is included the update file,the screen will  pop out the firemware updating tips automatically.
