I have Toyota C-HR 2017 and a Dasaita HA5462-Vivid10-CP-HD.
I'd like to connect the head unit to the factory fitted USB socket. There was no cable in the box for doing this, so am I missing a cable or missing something else? There were a couple of other USB cables (one with an audio in) but nothing fits....?
@Quick Yuan Please reply. How can we connect our head unit to factory USB socket? I've asked here many times, and I've emailed you many times - when will you answer?
perhaps the CHR has a cahnged to a non Toyota standard USB interface. You said that it does not fit. does it get bigger then the adatptor or smaller? If smaller....can the cotancts of the adapter fit into the contacts of the plug?
Perhaps you can adapt manuallly:
if smaller --> put a piece of paper/cardbord between adapter/plug
if bigger --> perhaps a manual cutting of the supplied adaptor can do the trick
@Mr Pink i got the same problem, i also got a toyota hybrid build 2017 and are also missing that cable and others in the box, also i notice in the canbus settings i dont see any toyota chr in there only rav and camry settings
anyone know what these 4 cabels are that are left from the toyota chr ? and does it supossed to not connet to anything when installing the dasaita unit
