Hi, Have got the DAB pack for the max 10, but the ariel that comes with it is pretty naff. The music cuts out and blips and farts.
Anyone out there know how to connect it to my existing ariel? I have a 2017 Quashqai.
This is what you need. Nota bene this is for GPS so you need to modify the connector a tiny bit.
I'd agree. My bench testing with the DAB antenna hanging off the venetian blinds up against the window shows variable connectivity during significant rain. Dry, sunny weather, no problem.
So, I'm planning on giving this a go:
The plan is to use the existing antenna to provide input to the DAB (SMA Female connection on the Dasaita USB DAB unit) plus the AM/FM antenna input to the head unit via a single feed. I initially tracked up the wrong path because I didn't fully understand the connector terminology. The linked unit offers a straight fit without additional adapters or performing cable surgery to splice something else in.
When I get it all rigged up and operating I'll try to remember to report back.
For info, the connector that I referred to above has been installed and works fine.
buongiorno , ho collegato DAB+ DASAITA a un PX6 DASAITA ma la connessione e' instabile , il segnale va e viene qualcuno ha qualche idea su cosa puo essere e come poter risolvere.
grazie
