No audio on 2017 Civic Coupe Ex-T
  • Dasaita 9” Inch Car Stereo (this product: https://smile.amazon.com/dp/B08Q3HGG7N)
    Installed per the included instructions and everything is working (wifi etc.) but I am not getting any audio from the unit at all.  I assume this had to do with my Ex-T trim having an amp possibly?  Any clue on how I'm supposed to modify the harness to account for this?
    Thanks in advance!
  • @James Noles
    1)If your unit has an integrated amplififer...you must check that you received a Canbus Box
    2) Configure correctly the canbus on Factory Settings  (password 126)
  • Hi. Just installed g12 in my 2018 ext. it has an amplifier. I am also not getting any sound. It came with the cambus and using 21. Do I need a different harness?
  • @James Noles did you ever find a solution?
  • I am having the same issue no sound. Canbus is on 21. Anyone have a solution
  • @Jove Heller
    The front&back side clear photo of OEM radio
    Please confirm if your car has these OEM Features ---
    Steering Wheel Control/ Factory Camera/ Amplifier(with or without).
    This is an old post but I still have not gotten sound out of this unit.
    Order Placed: April 25, 2022
    Amazon.com order number: 112-3881222-9961007
    I purchased the CB100 harness but still no sound. I need a picture of the CB100 unit connected properly to make sure I am doing this correctly.
    Pictures of OEM unit:
    Back of OEMSide OEMFront OEM
    Picture of Dasaita unit:
  • @James Noles
    Please check the CANBUS Settings NO.21 : Settings>Car>Factory Settings:126 >CANBUS>NO.21
    Please notice to connect this audio cable.
