Scout 7.2.4025 and duplicated scout notification
  • I just update to rk3399-userdebug 11 RQ3A 210705.001eng hct2.20240319.102515 and Scout 7.2.4025 and I noticed that in the notification area there are 2 Scout notifications.
    Those cannot be cancelled as it's possible with "standard" notifications coming from others app.
  • @Mcgyver83 Please do not worry and it's normal.
  • Ok, thanks!
    Is it ok if I disable notification for Scout app (scrol down on the notification, settings, disable)?
  • @Mcgyver83 Please Go to Settings > Apps&Notification and then you could disable the notification of Scout.
  • I went to Scout Notification settings but is not possible to toggle the selection.
    I tried many times tapping on the toggle but it stays on the right.
  • @Mcgyver83 We've confirmed with the engineer that the notification cannot be hidden unless you're not using the Scout UI. We apologize for any misunderstanding.
  • Ok.
    So if I replace Scout launcher (is it correct to name Scout launcher?) I will be able to hide Scout's notifications?
  • @Mcgyver83 We are sorry that it could not be hidden in the same time.
