Purchased from Amazon under Dasaita account,
Order date, Jan 17, 2025
Order # 113-1720720-8731463
(Model: QCM6125)
Dasaita Android 13 Car Stereo for Toyota Tundra 2014-2021 with Wireless Apple Carplay & Android Auto, 10.2" Touch Screen Head Unit, GPS Radio, 6G RAM 64G ROM, Bluetooth 5.0, 5G WiFi, 4G LTE
After installing the headunit. took about 45min. love the plud n play
radio worked great. then i noticed the radio sound cutting in and out on the passenger side of the truck.
i have tried using the Mixer to see if the speakers are working and its not picking up any speaker.
i have no Amp in the truck.
Is there an update i can install on the radio ?
@Adam McKinney
Thanks for your message.
Please firstly check if you have connected the speaker cables properly to ensure no loose connection.
In order to confirm your current version, please go Settings > About Machine,
All conection are good. I have removed the radio multiple times to make sure all conections are good.
here are a few picturees of the info you requested.
will need to figure this out before i cant Return or replace items: Eligible through March 7, 2025
Dear adam,
zst27_sc138_13_(20250226)
https://www.dropbox.com/scl/fi/hskmzj675wwjh9gs67emi/update.zip?rlkey=8td73qmw1bp0zwqud98b3e8hx&dl=0 |
1.Download the documents ① through the link on your computer/laptop.
2.Format the USB drive(FAT32 Format)before copying the Update.zip file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
After completing system update,it will display "20250226"here,please check it here.
If the issue still happen,please kindly get back to us.
