Hi all,
I have a weird issue with the microphone on my MAX10.
Sometimes when I start the car the mic just doesn't work on calls, voice search etc. Restarting the car (and head unit) fixes the issue.
I've noticed than when this happens, if I launch Zlink, this message will appear:
"In order to use voice recognition normally, please close the voice assistant wake-up function"
What does it mean and how can I fix this issue?
I have 'Ok, Google' detection on, if that's somehow relevant.
TIA
What Firmware are you using?
Have you tried to install the latest frmware available for your unit?
Oleg,
I saw a thread similar to this on the XDA forums, the problem is indeed the 'ok google' detection, I believe if you disable that the problem will be resolved.
I have a different problem with the mic. I have a Vivid 11/Android 11 for Camry and my mic sounds like a robot. I have tried everything from moving my GPS antenna to removing the aux mic. I even tried putting tape in the hole of the internal mic. It is unuseable
