What is the correct model number CanBus used for a 2010 4runner SR5? I was sent one labeled TY-SS-01. While the bag it came in is labeled CB005-1.
None of the cables match in size and pins do not line up.
@DeAngelo Fernandez
the canbus CB005-1 use for car has JBL amplifier , you can send your OEM radio to have a check
https://www.dasaita.com/products/dasaita-harness-for-toyota-keep-original-function-swc-amplifier-cb005?_pos=1&_sid=5eac50157&_ss=r
Hi, DeAngelo Fernandez
We've got your requirement, and will contact with you by message.
Pls reply us ASAP, thanks.
I have a 2010 4Runner limited, the radio is connected perfectly, but there is a problem, I can't establish a canbus connection. when the temperature changes, nothing appears on the screen, there is also no indication when the doors are opened. What should I choose in the settings after entering 126 in the canbus tab? SW version 11
Hi there
I have a 2013 4runner and I just installed a G12. The OEM radio was one with a CD player. The wiring harness included with G12 that I used did not have CANBUS module on it - why is that?
Also there were no plugs included to allow Steering Wheel Controls, and the amplifier button (party mode) does not work any more
Please help!
