I am installing my new dasaita android head unit in my 2009 Tch and have the JBL, so I ordered the canbus adaptor (all off amazon)
The canbus harness barcode reads: Model: TY-SS-01/RP5-TY-002For: Toyota Vehicles with JBL Audio System
Although my steering wheel controls are working I am not seeing the reverse camera trigger, nor am I seeing any door open indication or HVAC indicators on the dasaita screen.
Which canbus setting do I use?
Also, am I correct in assuming the canbus should trigger the backup camera? It isn't and the connector with the reverse wire doesn't seem to have a mate from the Camry.
Thanks!
So, 2 weeks have passed and I'm going to reply to myself so that others don't have to wait for answers.
The "Canbus" adaptor for this car isn't a canbus adaptor. The canbus wires don't even attach to the head unit.
Pins 1 &. 11 are completely empty on the head unit and they are the canbus TX and RX.
I had to cut into the head unit's reverse wire that went into an unused connector. I suspect this connector is used and would work for cars that have a factory backup camera, and mine was aftermarket.
I will be doing some digging later this month to see if I can identify the car's canbus TX and RX and wire it to the head unit to see if I suddenly get piles of data from the car. I am pretty confident that it is there as one of the factory headunits does display hybrid battery and other systems data on it. Perhaps that will unlock a lot of features that simply aren't available with the Dasaita's current setup.
There is no door open or engine data available on this unit with the recommended "Canbus" adaptor.
CAnbus TX & RX signals from your car must be connected to the CANBUS BOX (check that some of the canbus box wires are connected to the Car Plug - and check which are the car RX TX signals) ....Canbus BOX send differnet signals (converted signals) to the Headunit....probably by menas of some specific data pins... so ot necessaryly must use the Canbus pinout of the Dasaita connector
I am having same issue with reverse cam. Any luck on finding trigger wire going into receiver?
Mine is a 07 camry with jbl but no factory backup camera.
Oh, I have a lot of respect for Toyota cars for quality and reliability. Recently I found a website with a large selection of used Toyota cars and I think that in the near future I will make a purchase of a car. I compared prices and realized that it is better to buy a used car for example 2020 at a normal price than 2023 at a sky-high price.
